Is there a function that allows an error message to appear when trying to machining with a drill tool larger than the hole feature?
daroa3109
daroa3109
FTKnur
Hi @daroa3109,
no, such a function does not exist in inventorcam. But why do you need this?In the Simulation you will see all too big drilled holes. Also you get every time an error, if you use a larger drill/tap for tapped holes.
