- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here's a video that I found on how to probe within multiple work offsets in Fusion.
https://youtu.be/STJ_m2lTEZ8?si=pX-2bYc7Aj4oQo4K
The idea is that you may want to have a probing operation "work" in one coordinate system, i.e. G54 but then update the results of what it found in another CS (G55) and then run some machining operations in G55. So G54 would likely be your "vice" coordinate system and never change, but G55 would be your "this is what I found and we're going to machine here" coordinate system.
Unless there's something that I'm missing, I can't seem to get Inventor CAM to operate in this way. I've looked through the help files and done some testing, but it appears that the WCS override features in both the Setup and the actual Operation screens affect the CS that the probing operations function in, not what they output to. My understanding is that setting them to 0 or 1 both will post to G54, "2" will be G55, and on from there. But when I do that, this makes the operation "run" in G55, not run in G54 but output to G55.
Hope this makes sense. Can anyone assist? When I get time today, I'll setup a dummy part and upload it for demonstrative purposes.
