I am using Inventor 2023 with the 2023 CAM ad on. I have a Haas mini mill with next generation controls. The post processor is not in the program as a default. So I downloaded it from the Autodesk website and added it to the correct folder. It does show as an option, however when I post process this error message comes up-
Error: Failed to evaluate post configuration.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Monday, January 8, 2024 4:01:00 PM
Code page changed to '20127 (US-ASCII)'
Error: ReferenceError: createOutputVariable is not defined
Error at line: 481
Stack dump:
@C:\Users\Public\Documents\Autodesk\Inventor CAM\Posts\haas next generation.cps:480
Failed while processing global script.
I have tried to download previous versions of the processor, same issues.
This is where I got the file from- https://cam.autodesk.com/hsmposts?p=haas_next_generation
It says Fusion 360 at the top, but its the only source I can find. When I search for inventor files this is what comes up.
Am I missing something? In the past I have used Fusion with no problems, However I would like to stick with Inventor.
I have attached the inventor file- Simple block with a hole.
I attached the post processor file.
Thank You
