Hello-
I have a problem in Inventor CAM 2024 where the specified horizontal lead-in is not respected, as shown in the picture below.
The specified radius for the lead-in is 0.037, but instead of this, a large arc is generated which ends in a sharp right angle when the tool contacts the stock. I have found a similar issue here: https://forums.autodesk.com/t5/fusion-manufacture/2d-adaptive-shortening-lead-ins/td-p/7657788 but no real solution was found. I have reinstalled inventor CAM, tried this on numerous parts, and it just seems broken. Is there some setting I am missing? what might cause this? I'm kind of pulling my hair out here. I have attached the .ipt that reproduces this.
Thanks!
Lincoln
This looks like an error.
Kacper Suchomski
You can use other strategies.
This one clearly has a bug.
Kacper Suchomski
