HSM Support Forum
Inventor Cam , breaking edge with ball mill
4 REPLIES 4
JamesCipolloni7683
364 Views, 4 Replies
I need to break an edge along a compound angles, basically along 2 chamfers intersect using a 1/8 ball mill. I have tried using trace , it follows the path in simulation but not with posted g-code, in the passes tab I use sideways compensation "left" but it does not add a G41 cutter comp,   I attached files,  pic /g-code and .ipt .
Any help /suggestions would be appreciated!
Jim
CIPCO
4 REPLIES 4
FTKnur
in reply to: JamesCipolloni7683
Hi @JamesCipolloni7683,
trace does not support in control compensation, that what you can select is only for the calculation. But do you realy need compensation for deburring?
JamesCipolloni7683
in reply to: FTKnur
Thanks for the reply,  I may not need to cutter comp, there does not seem to be any relationship to what edge I select and where the ball mill actually goes , not much explanation at all on this,  we don't do close enough in this business .
using left in "sideways compensation" is it shifting the tool by 1/2 the dia.?  autodesk does not explain this.
FTKnur
In your Profile operation is the "chamfer" option selected. If you select this, then the calculation is realy crazy for a ballnose cutter. Sometimes things are a littlebit trial and error in HSM 😞
I have used a modeled chamfer and flow toolpath with a ball mill to get those pesky chamfers.
