HSM Support Forum
Inventor 2024 CAM - Missing Selections
3 REPLIES 3
john3NHRC
454 Views, 3 Replies
If I run Generate Tool Path in Inventor 2019 everything works fine.
If I run Generate Tool Path in Inventor 2024 does not work.
I am using the same .ipt file on both so I know it isn't the file.
The error I am getting is: Error: Setup1: Model has 1 missing selections.
The example that is given in Autodesk show Fusion 360 on how to resolve the issue.
I cannot replicate the solution in Inventor 2024.
Even if I create a dead simple drawing I still get this error.
Why does it work in Inventor 2019 and not in Inventor 2024.
I need it to work in Inventor 2024.
3 REPLIES 3
Attach your file.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
I have attached the inventor file to my original post.
Thank you for helping out.
john3NHRC
in reply to: john3NHRC
I got it figured out.
