hsmworks problem with Solidworks ..
Aadithya01
Advisor Advisor
Message 1 of 39
Aadithya01
Hey Guys ,
Please see the below google drive link having the video of the problem that I am currently facing.
I am currently having this issue when I installed HSMWORKS 2018 in my system having Solidworks 2017 . Whenever I call for an operation (CAM) and try to generate the toolpath - immediately Some other backend windows popup and get populated and doesn't allow to work further - Please see the task manager in my video
HSMWORKS SOFTWARE ISSUE WITH SOLIDWORKS 2017
https://drive.google.com/open?id=0BzMseUdQJiwhWG9HYUdfUDdWNWs
May I know the cause and solution for this problem
Note : in the same machine I installed inventor 2018 and inventor hsm 2018 and there is no issue with it ..
Accepted solutions (3)
Replies (38)
Message 21 of 39
Laurens-3DTechDraw
You could try updating your drivers as the latest version for your card is 15.7.1, and those actually are for Windows 7 support.
Where 8.783.2.2000 is from before windows 7 was released.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 22 of 39
8.783.2.2000 with this same version of graphics card solidworks 2017 SP3 is working so how is it not supporting for hsmworks 2018.
Please note : in the same machine inventor & inventor hsm is installed & they are working properly
is the graphic driver really an issue?
Thank you
Message 23 of 39
Laurens-3DTechDraw
Thank you
It could be an issue.
Since the vast majority of users doesn't have this problem, it's an easy thing to try and see if it solves the issue.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 24 of 39
lenny_1962
Thank yOu
remember SolidWork has their way of using graphics that Autodesk doesn't control, so once the HSMWorks adding is activated their could be conflicts between all the shared dll's that both programs use.
this becomes more prevelent as your PC get older do to hardware and drivers not supporting current releases softwares, heck could even be Windows update related
again I ask is SolidWorks and HSMWORKS the only program running or do you have others like outlook, Internet Exploder, Chrome, inventor????
and by the way AMD cards are crappy always have issues with them, Radons are gamer cards one big no no for SW
Message 25 of 39
HEy @lenny_1962@Laurens-3DTechDraw@jeff.pek
The problem is still existing even after installing the graphics driver to 15.7.1
Kindly please help
Message 26 of 39
hi @Laurens-3DTechDraw & @Steinwerks
Even the graphics driver update for latest version it dint solve the issue.Only when the dot net components in windows update were updated it resolved the issue.
Thank you all for your help @lenny_1962@Laurens-3DTechDraw@Steinwerks@jeff.pek
Message 27 of 39
jeff.pek
Wow, interesting. Is there a particular package/version that seemed to do the trick?
  Jeff
Message 28 of 39
Hsmworks R3.42084
Solidworks SP3
Message 29 of 39
jeff.pek
OK. What about the .NET components you referred to?
  Jeff
Message 30 of 39
I updated all of the .NET related components in the windows update & installed them.Then it works correctly.
Message 31 of 39
lenny_1962
I did state that it could be windows update related in an earlier reply
Message 32 of 39
Aadithya01
Hey @lenny_1962
Like you stated yes only when we did the windows dot net components update the software worked fine .. Thank you so much man
Message 33 of 39
hi my freind..Lucky you that with updating Net.Framework you dont have problem now...i updated my windows package but it doesnt work. 😞
What should i do now?? plz help...
windows 7 x64
solidwork 2016 srervicepack 0
hsmworks 2016 R3.40969
NET framework 4.7
Message 34 of 39
Aadithya01
Hey @Anonymous
Welcome to Autodesk Forums.. What type of problem are you getting .. Mine was - the background windows started to pop up and blocked my screen .. For that dot net components solved my problem .. Are you getting this same issue ..
Also since you are a hsmworks user . Try other development versions of hsmworks from the below link
http://cam.autodesk.com/download/hsmworks/
Are you a subscription user of Hsmworks .. If so please install the latest version of HSMWORKS .. or else install a higher service pack of hsmworks 2016 from the above link
Please note : hsmworks 2018 will support solidworks 2016
Message 35 of 39
lenny_1962
And you should install  service pack 5 for SolidWorks, that is if you are on subscription, SP0 always has issues.
Message 36 of 39
hi my friend..thanks for answer...i used hsm 2018 ultimate, but i have the
problem yet! 😞
what should i do??
Message 37 of 39
hi my friend... i used service pack 2 for solidwork in about 5 days later
but i had the same problem... are you sure that with service pack 5 can
solve the problem??
Message 38 of 39
lenny_1962
solve the problem??
As with any software that run together if there are issues that were not there prior to updating one of them to a newer update, then issues arise, there must be some compatibility issues between them. Since SW is so graphics driven maybe your video card and how HSMWorks and SW handle the drivers.
i have never had the issues you are having, so I would update to the latest sp to try, without having you PC it's all a crap shoot
Message 39 of 39
Aadithya01
Hey @Anonymous
Are you getting the same problem which I got ??
5 things you can try here....
1. hsmworks 2018 - try the latest service pack from the development version
2. update your graphics card to the latest driver.
3. Like @lenny_1962 said update your solidworks 2016 to the latest service pack (I think it might be sp5 or sp6)
4. do a Windows update - some components will fail to update .. but restart the update several times .. also concentrate on the dot net components...
5. if all the above dont work - raise a support case thru the autodesk partner portal - some technical support person might be able to solve the problem thru remote sharing
