HSM Support Forum
HSMWORKS Problem posting
8 REPLIES 8
Message 1 of 9
565 Views, 8 Replies
Hello. After post update I recive such error:
Error(C:\Program Files\HSMWorks\posts\haas st-10y (26.07.2017).cps:2294): ReferenceError: isSubSpindleCycle is not defined
Stack dump:
onCycle()@C:\Program Files\HSMWorks\posts\haas st-10y (26.07.2017).cps:2293
Failed while processing onCycle() for record 1388.
Error: Failed to execute configuration.
Stop time: Wednesday, July 26, 2017 4:25:03 PM
Post processing failed.
Do you have any ideas how to fix it?
8 REPLIES 8
Message 2 of 9
Laurens-3DTechDraw
What software and what version are you using?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 9
in reply to: Laurens-3DTechDraw
HSMWorks 2016 R4.41148
Message 4 of 9
My soft is HSMWorks 2016 R4.41148
Message 5 of 9
Before this update 07.11.2016 of the post everything was OK!
Post link
Message 6 of 9
Laurens-3DTechDraw
Ahaa,
Now I understand where this comes from.
The post processor is looking for a function in the software that isn't in your version.
Are you on subscription or maintenance subscription?
In that case, you could update and have all the benefits from that.
If not if you still have the old post use that one.
If you don't we have to ask @AchimN if he can check if they can make this post fully backwards compatible.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 7 of 9
Thank you for support!!!
Message 8 of 9
AchimN
Thanks for your feedback.
@Laurens-3DTechDraw is right, i´ve already modified the posts for full backwards compatibility.
The update will show up shortly into the library.
Achim.N
Principal Technology Consultant
Message 9 of 9
in reply to: AchimN
Thanks for operative support!!!
