Horizontal cant remember machining boundary between adjustments/regeneration
- Mute
- Permalink
- Report
I select a machining boundary for horizontal, Generate tool path and everything is fine. I edit operation to adjust (stock to leave etc.), and it fails to generate tool path. I go back to edit, and the original boundary I selected is incorrect. I have to clear the boundary definition and re-select the correct boundary. Then it regenerated fine, but I have to re-select any time i make and edit to the operation. Note, this boundary is from a sketch.
