Has 2D contour stay down ever worked?
Greg_Haisley
Message 1 of 25
Greg_Haisley
I have a machine with limited memory (64K) to be exact. Was trying to use 2D contour so I would get 2D arcs and get a smaller program size. Thought it would be nice to see the tool stay down while cutting the part. Can't find the magic button that enables this stay down function. Or has it ever worked is the question. If it is not ever going to work please remove the stay down UI.
FYI - In my part the 2D contour program is 33% smaller in size when compared to the 2D Adaptive program using the same step over settings, tool path tolerances and stock size. Just thought I pass this little tid bit of info along for those with older machines with small memory. I'm cutting aluminum so constant cutter load is not that big of a deal. The large program size is.
Replies (24)
Message 2 of 25
aaron
Have to try increasing the maximum stay down distance under the linking tab? right below the keep tool down tick box
Message 3 of 25
Steinwerks
It only works for finish passes.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 25
scottmoyse
Surely it should work for all passes? Jeff?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 5 of 25
Laurens-3DTechDraw
Even with a very tight calculation tolerance for the adaptive? For these types of machines it's usually best to have a tolerance of 0.001 mm and than you can use a smoothing of 0.01 mm for finishing and 0.05 mm or so for roughing work
How does a 2D Pocket to by the way? I never use it so not sure if it's able to do this though.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 6 of 25
scottmoyse
I couldn't figure out how to do an open pocket with the 2D pocket command last week... using stock contours and the 2D contour does however give you an open 2d pocket toolpath. And as shown here, its possible to create an open pocket with 2D Adaptive.
Scott Moyse
Message 7 of 25
Greg_Haisley
I should have mentioned that setting - I had it set to 99 inches. Should be enough to keep the tool down.
Message 8 of 25
jeff.walters
Greg I’m running this past the developers because it doesn’t make sense to me either.
Jeff Walters
Senior Support Engineer, CAM
Message 9 of 25
Rob_Lockwood
And on finish passes, it requires that the lead-in/out positions between two passes produce a straight line that's clear of the previous pass in order to allow stay-down linking.. It's a system that works well in the actual designed usage case (spring pass etc) but not so well if you're trying to rough material, finish floors, etc.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 10 of 25
Steinwerks
Why didn't I get that answer in this thread?  :-X
https://camforum.autodesk.com/index.php?topic=7305.0
Neal Stein
Find me on:
Message 11 of 25
Steinwerks
Welp, having this problem now too. Why would this jump up? Stay down distance set to 10 inches. No roughing passes, repeat finish passes on.
Edit: it seems that it only treats the repeated pass as a finish pass.
Neal Stein
Find me on:
Message 12 of 25
This might be obvious, but I was trying to get a "stay down" tool path the other day, and the initial machining boundary I had set would not let it stay down. Just a thought.
Message 13 of 25
Steinwerks
There is no boundary, just a 2D Contour operation.
Neal Stein
Find me on:
Message 14 of 25
Crap I think I was using Adaptive sorry.
Message 15 of 25
Greg_Haisley
I don't want to come off as a CAM bitch, but there are many cases where this software offers up toolpath generation options yet the software ignores these user settings. In turn creating frustration for the user base.
A few examples of my point.
Plunge point
drill point
slot stock to leave on the side - the slot just follows the centerline of the shape, there is no side cutting done.
feed plane ignored for the use of rapid to depth, works in same cases but not when roughing out an open pocket
the stay down option as in this thread in all strategies
the whole turning module
My point is - if the software offers up a different tool path options. Then these options should work. Is this too much to ask?
Does any developer have the responsibility of checking all tool path options with regards to different strategies?
Remember your mission ADSK.
Our mission
To be the leader in CAM technology, by delivering truly innovative, intuitive and high performance software that provides our customers with the competitive edge they are searching for.
Rant over - have a great day everybody.
Message 16 of 25
lenny_1962
Greg Nicely put.....
I'll joint you as a CAM Bitch  8)
Message 17 of 25
Laurens-3DTechDraw
As far as I know it doesn't work when you have stock contours enabled.
Laurens Wijnschenk
3DTechDraw
Message 18 of 25
Greg_Haisley
Why would that scenario be important? The whole idea is for less code in my case. One move back to the next cut is less code than a retract, make the same move in X and Y then an approach in Z. Makes no sense.
Message 19 of 25
Laurens-3DTechDraw
Because with the stock contours enabled the operation get's a little more clever and understands it can't always take the shortest route to the next pass. Because stock could be in it's way. If you don't have stock contours on and set it to make multiple passes and have the keep tool down it usually does exactly that but that kind of only works for finishing or when having bigger lead radii than step-over.
Laurens Wijnschenk
3DTechDraw
Message 20 of 25
Greg_Haisley
The whole idea is to use the stock contour, so that the toolpath is smart and knows were the stock is. The toolpath doesn't cut air. With your idea it will cut air and that defeats the idea of an innovative toolpath does it not?
I was expecting the tool stay down to behave like the 2D adaptive. Not like the 2D pocket where the tool path snakes from one pass to the next. Another question is - if this gets fixed where's the high feed rate value for the tool stay down setting? I see the lift amount but no high feed rate value.
If I were calling the shots I'd just remove this as it does not perform as it should.
Looks like this along with other strategies are half baked.  ???
Just like cake that's half baked - looks good on the outside but a mess on the inside.
