Message 1 of 25
Has 2D contour stay down ever worked?
- Mute
- Permalink
- Report
I have a machine with limited memory (64K) to be exact. Was trying to use 2D contour so I would get 2D arcs and get a smaller program size. Thought it would be nice to see the tool stay down while cutting the part. Can't find the magic button that enables this stay down function. Or has it ever worked is the question. If it is not ever going to work please remove the stay down UI.
FYI - In my part the 2D contour program is 33% smaller in size when compared to the 2D Adaptive program using the same step over settings, tool path tolerances and stock size. Just thought I pass this little tid bit of info along for those with older machines with small memory. I'm cutting aluminum so constant cutter load is not that big of a deal. The large program size is.
