I try to add a small edge break to all my parts whenever feasible. Top edges are done with a small 90 degree cutter using the chamfer feature in the contour strategy.
For side edges, I have been editing the model to actually add a tiny .010" chamfer to the corners. However, I'd like to stop this practice for a number of reasons. Now I create the toolpaths in an assembly rather than the part file itself, and I don't want to have to edit the part file.
How can I make the tool path cut the corners on the parts?
Below is an example - I'm going to mill two parts in the orientation below, and want to edge break the noted corners which the designers left sharp. I always have "roll around corners" selected, but it doesn't edge break - just minimizes the burr.
The only solution I can think of is to create a sketch and draw in the corner chamfers, which is not a very efficient way around the problem.
Solved by MattWallaceVRTX. Go to Solution.
In Solidworks, you can put in an assembly level chamfer (or fillet) and you have an option as to whether that propogates to the part file.
