- Mute
- Permalink
- Report
Dear Community,
I come to you after having tried ALL milling strategy offered by Inventor HSM 2017.
Here is my issue:
I want to mill a simple contour. The contour of this number 3. see pic below, the contour is in blue:
I want to mill this contour with a 90° chamfer tool and mill the inside of this contour as well. See pic below,
For the moment all I get is the tip of the tool to follow the contour. This is not what I hoped for.
So, to explain a little bit further, I want the edge of the tool (red line) to follow the contour. This would result of having the "3" number milled in 3D, with a V-shape cross section, following this 2D path.
(To refrase, I would like my tool to go up and down to match the width of the area to be milled. Hence, the depth of the milling would vary according to the width of the area to be milled.)
I have tried all milling strategy and they mostly return this error message:
exept for 2D contour strategy and Slot strategy. However, slot strategy do not produce a toolpath as it shows "None" in the browser tree.
So the solution I had in mind is to stay with this 2D contour strategy but fine tune some parameter that would allow the edge of the tool (in red) to follow the contour and not the tip of the tool to follow the contour.
I would really appreciate to receive guidance from anyone who might have come accross such issue,
Many thanks in advance,
Best Regards
Jules
