Update GRBL post to allow laser program posting
Now that GRBL has been publicly released with laser mode as one of it's options. Would it be possible to have the post team add laser function to the GRBL generic post? GRBL uses M3and M5 for laser control.
https://github.com/gnea/grbl
9 Comments
A spindle/PWM value is also required to turn on a laser - ex: M3 S255 - in GRBL v1.1e.
Thanks for that Jeff,
Also, the Smoothie post kind of works for GRBL but you have to make some changes to the post file to work with GRBL. I was able to get it working a while ago but I don't remember what I had to do to the post to make it work.
It would be good to have user parameters in the post options screen to change power range for the different laser modes as some people run max laser power at S255 and some at S10000 depending on how the firmware is setup for GRBL. I have attached an image to show what I mean.
atrueresistance
+1 on this.
+1 on this!
AchimN
AchimN
Status changed to: Accepted
AchimN
Initial beta post is now online:
https://cam.autodesk.com/posts/?p=grbl_laser
Any feedback is very welcome.
3dfixer
Observer
grbl when used with a laser uses m3 to turn on, m5 to turn off
also uses s to set power, s0 is basically off, s255 max power
below is code produced using grbl laser post to cut a small square
(square)
G90 G94
G17
G21
(2D Profile10)
G54
G0 S250 M4
G0 X11.1 Y1
G2 X11 Y0.9 Z0 I-0.1 F400
G1 X1
G2 X0.9 Y1 J0.1
G1 Y11
G2 X1 Y11.1 I0.1
G1 X11
G2 X11.1 Y11 J-0.1
G1 Y1
G1 S0
M30
it should look something like this
(square)
G90 G94
G17
G21
(2D Profile10)
G54
G0 X11.1 Y1
M3 S250
G1 X1
G2 X0.9 Y1 J0.1
G1 Y11
G2 X1 Y11.1 I0.1
G1 X11
G2 X11.1 Y11 J-0.1
G1 Y1
G1 S0
M5
laser should move to start position, switch on laser, cut profile then switch off laser
here example of 4 squares
(4_squares)
G90 G94
G17
G21
(2D Profile1)
G54
G0 S250 M4
G0 X10.688 Y10.9
G1 X1.1 F400
G1 Y1.1
G1 X10.9
G1 Y10.9
G1 X10.688
G0 X10.9 Y21.313
G1 Y30.9 F400
G1 X1.1
G1 Y21.1
G1 X10.9
G1 Y21.313
G0 X21.313 Y21.1
G1 X30.9 F400
G1 Y30.9
G1 X21.1
G1 Y21.1
G1 X21.313
G0 Y10.9
G1 X21.1 F400
G1 Y1.1
G1 X30.9
G1 Y10.9
G1 X21.313
G1 S0
M30
as you can see laser doesnt power off between squares
ive looked at post processor code and its beyond me what to change
hope this helps, i'll try again when post updated
