Show only
Search instead for
Glen, how far off is the generic fanuc mill-turn post? Have you had a look at it? it looked to contain twin turret + y-axis support out of the box, so presumably not too far off from what you need.
Oh, it exists.. Shoot me an email if you really don't already have a copy.
// fixed settings
var firstFeedParameter = 1;
var gotYAxis = true; // specifies if the machine has a Y-axis
var yAxisMinimum = toPreciseUnit(-50.8, MM); // specifies the mimimum range for the Y-axis
var yAxisMaximum = toPreciseUnit(50.8, MM); // specifies the maximum range for the Y-axis
var gotLiveTooling = true; // specifies if the machine is able to do live tooling
var gotCAxis = true;
var gotSecondarySpindle = false;
var gotDoorControl = false;
var gotBarFeeder = false;
var gotMultiTurret = true; // specifies if the machine has several turrets
