Post Processor for LabVolt 5600 CNC Mill
The Project Lead The Way curriculum uses the Lab Volt 5600 CNC mill.
I have received a generic labvolt post processor but we are having many problems with it.
The G&M codes need to include two digits and need to be placed in front of the x y z coordinates or command.  For example  "M06 7" is the accepted code for tool change to tool #7.   "M03 S1000" is correct format for spindle speed but it is not the format generated by the generic Labvolt post processor.
Also LabVolt 5600 does not use M1 to stop before a tool change.
I am having problems with plane changes G18 & G19 plane specifications too.
Labvolt is crashing prior to completing the code unless I manually edit the end of the code.
8 Comments
Last year I unsuccessfully tried to get Autodesk and Labvolt talking to work out the bugs in the original post Autodesk created.  Autodesk was very responsive, LabVolt/Festo, not so much.
AchimN
Status changed to: Accepted
AchimN
Initial post processor can get downloaded here:
https://cam.autodesk.com/posts/?p=labvolt
Any feedback is much appreciated.
Trying to download Lab Volt 5600 mill post for Inventor 2017 HSM and the blog sent me to a page that had an expired security.  I still need the post.
nancy_c_smith
Newest version of LabVolt post processor is better but still needs some changes.
After changing feed rate, the G code must be restated even if it is supposed to be modal.
for example- this will not work :
G01
X1
X2
F9
X3
For the LabVolt the modal Gcode must be restated after changing a feed rate- this will work:
G01
X1
X2
F9
G01
X3
nancy_c_smith
G01
X1
X2
F9
X3
G01
X1
X2
F9
G01
X3
v
nancy_c_smith
G01
X1
X2
F9
X3
G01
X1
X2
F9
G01
X3
Please help
