Part Probing Cycle Implemented into Hurco post processor
We have noticed that the Hurco post does not support the part probing cycle from the HSM software.
It would be a really strong benefit to have this implemented for the Hurco post.
10 Comments
AchimN
Would be excellent for HSM and F360
Any update on this?
radu_pantiuc
It would be very helpful to be able to post process probing cycles from HSM to hurco machines, but from what I saw the post processor does not have this implemented.
any update on this?
lenny_1962
I believe the problem lies on the HURCO NC side. If you look in the manual there is no gcode for a variety of probe options.
I wanted this too and was reading, only found simple options, unlike all the options on the conversational side of the control.
I guess the only option, haven't tied it, is to do the NC merge to a conversational program, haven't tried that either.
Has any of you contacted your HURCO dealer? I haven't.
@lenny_1962
That's essentially the workaround.  Use a conversational program to run a part probe, then call NC program(s) as sub-programs.  The caveat is that the machine must be set up to use absolute tool length to be able to store probed values as offsets that can be passed to the sub-program(s).
serge.quiblier
Hi All,
we have created an Hurco post supporting : the part probing, the wcs probing and the surface inspection.
This post has not been tested, so use it with care, and don't hesitate to provide feedback.
It will allow us to improve it or fix it.
Link to the beta Hurco inspection post
Regards
