To improve the quality and the precision of the complex surfaces obtained by high speed milling and increases the service life of the CNC machine or Robots, it is necessary to integrate the manufacturing parts process parameters as a boundary condition in the calculation of the tool path: Dynamics of CNC machine axes, the parameters (numerical and kinematics) of the computer numerical control, parameters of the smoothing mode, …
I am writing to inform you that I am in the process of developing of new CAM programming algorithms approaches allowing to integrate the principal parameters of the CNC units (smoothing mode defined in the CNC unit, anticipative setpoint mode of the CNC unit, maximum capacity of the feed-forward control, the effect of the axes inertia variation,...).
The new algorithms developed result in a significant improvement in the accuracy and roughness of the free-form surface parts produced by high speed machining (CNC machine and robot).
The proposed project is in the form of new mathematical models for calculating the tool path integrating the drive controller parameters as a boundary condition.
The first model was validated and ready to be exploited.
The second is currently being programmed in Matlab.
The third require some experimental testing
In addition to these three projects, several other guidelines can be developed in this area with the aim of producing. a new intelligent generation of CAM software.
Are you interested in collaborating in order to finalize the study ?
Best regards .
Essid Mohamed.
Teacher researcher : ISET SFAX and UGPMM-ENIS ( Tunisia).
