Needing Post for a C.R. Onsrud 145M12 CNC Router with a Fanuc 0i Controller
I am aware there is a post for a C.R. Onsrud with a fanuc 31i controller that supports 5axis, but the machine we have is just a 3-axis.
3 Comments
bob.schultz
The CR Onsrud post processor has an option to disable 5-axis support for use on a 3-axis machine using the 'Has 5-axis' property, which can be set when you post process.  Have you tried this?
JocelynFR2F8
Observer
I need a Post for a CR onsrud RH CNC Router with a Fanuc 0i Controller, can I use the same Post for a C.R. Onsrud with a fanuc 31i controller that supports 5axis?
bob.schultz
The C.R. Onsrud post should be able to run a 3-axis machine with a Fanuc 0i Controller by disabling the Has 5-axis property as described above.  You may find that the post requires minor changes to handle any special features you have on the machine.
