generic Techno CNC post
We are working on a generic Techno CNC post processor and we would be happy to get some feedback from you before we put it into the library.
I add 3 properties for 3 variants of output for HD machine without Toolchanger, HD2 with Toolchanger and HDS with Toolchanger machine.
Please test all 3 variants and let me know if i can improve something.
Please feel free to download and test it:
http://cam.autodesk.com/posts/?p=techno_cnc_router
14 Comments
AchimN
Status changed to: Accepted
AchimN
cjbehling
Hello
I am using a TechnoCNC Venture Series and the post processor seems to output a "generic" g-code file, not one that follows the specified format from TechnoCNC. I have tried all three of the user defined machines in the post and have had no success. I've posted the format TechnoCNC sent me below. If you could modify the post processor to reflect these changes I would appreciate it.
Thank you
HDS G CODE FORMAT
- IJ arcs must use ABSOLUTE coordinates.
- Alternately, R arcs may be used.
- G and M commands must be 1 per line.
- Must have a delay after every ‘spindle on’ command (DLY,5).
- Must have a user offset defined (UAO,1), (UAO,2)…
- G27 after every tool change to ensure continuous motion.
- Header should look like this:
o G70  defines units as inches
o G90  absolute coordinates
o G40  disables cutter comp
o G80  disables fixed cycles
o G17  arcs in XY plane
o G27  cont. operation w/ speed reduction on corners
o M143  lowers pop-up pins
o M49  lowers dust shroud
o G600  calls up cut parameter settings
o (UAO,1)  calls up user offset
- Footer should look like this:
o M5  spindle off
o M48  raises dust shroud
o G79 Z0  raises Z axis to home position (optional)
o M30  ends program
Sample file:
G70
G90
G40
G80
G17
G27
M143
M49
G600
(UAO,1)
T1 M6
S18000 M3
(DLY,5)
G27
G00 X2.5607 Y2.5607 Z0.1500
G01 Z-0.2500 F50.
G03 X1.5000 Y3.0000 I1.5000 J1.5000 F100.
X0.0000 Y1.5000 I1.5000 J1.5000
X1.5000 Y0.0000 I1.5000 J1.5000
X3.0000 Y1.5000 I1.5000 J1.5000
X2.5607 Y2.5607 I1.5000 J1.5000
G00 Z0.1500
T2 M6
S12000 M3
(DLY,5)
G27
X7.5000 Y3.0000 Z0.1500
G01 Z-0.5000
Y0.0000 F200.
X4.5000
Y3.0000
X7.5000
G00 Z0.1500
M05
M48
G79 Z0
M30
KerimY
Hello @cjbehling,
thank you for feedback.
I'm on vacation next week will be updated it the week after.
AchimN
Looking for more feedback for this post processor. Make sure that you are using the latest version from the library since there have been a couple of updates for that post.
I'm an industrial technology teacher who's been using HSM since its release with a Techno CNC and other machines. Since updating to 2019 this fall, our .nc files have the machine making tons of circles. In most cases the actual tool paths that we want still exist, and you can sort of see them.
We changed the setting to- Using IJK's to NO, and use Radial Arcs to YES. This solved some issues, but also created a few- With those setting not all of our paths are previewed as intended.
luke.douglas831
Observer
Hello. I am currently trying to use Fusion 360 to output to the Techno LC series on our college campus. I am having a similar issue to the images above. I can get the file to display somewhat correct but there are no arcs present.
luke.douglas831
Observer
Here are some of the images from what I described above. Any input appreciated!Default settingsDefault settingsTweaking IJK and Arcs optionTweaking IJK and Arcs optionTweaking IJK and Arcs optionTweaking IJK and Arcs option
I'm sorry I hadn't responded to this post. In case you have not figured out your issue- Changing the machine type in our post processor cured our issues. It defaulted as HDS series, and I from what I remember we changed the machine type to HD Series for our LC Series 4896.
jonathan.mi6
Community Visitor
@Anonymous how did you change the machine type in the post processor?
Forgive me because I'm not near my desktop computer that has Inventor
installed.
But- When you are in the post processor window that has your different
"posts" there is a window in the bottom right corner. This window has a
bunch of options, allow helical entries, use IJK, use radial arcs, a bunch
of other options. One of them will be something like "machine type". The
default is HDS series, and we changed ours to HD series. That fixed all of
our issues.
I'll be back at work tomorrow and can take a screenshot if you still need
it.
jonathan.mi6
Community Visitor
Oh my, my bad actually. I read the entire post wrong and realized this was for the HD series routers, the one I work with is a LC one. Been trying to figure out the post for this machine (it won't do helixes and 3d movements properly but the machine can move all 3 axes at once) but can't seem to find out where to get the exact post for my machine. (Currently using the generic RS-274)
miolda
Community Visitor
I am having the same issues as above has anyone made and progress on this? I am using a Techno LC plus. I also get the preview with the added circles and arcs
Benjammann
We just bought a Techno CNC Titan series. Does anyone here know if this post would work for us? Thanks!
