cancelar
Mostrando los resultados de
Quiere decir:
generic siemens millturn post processor
We are working on a generic siemens millturn post processor and we would be happy to get some feedback from you before we put it into the installation.
Feel free to download and test it:
http://cam.autodesk.com/posts/?p=siemens_mill-turn
Thanks.
12 Comentarios
AchimN
El estado se ha cambiado a: Accepted
No aplicable
Hi AchimN, Is there a generic mori-seiki mill-turn post in the works? Many thanks Matthew.
@Anonymous
What control is your request based on?
No aplicable
It's a NLX 2500Y mill turn lathe, the one I was wanting to have a go at. I was looking through the posts, and I was thinking of modifying a hass one to suit?
@Anonymous
Is it a fanuc control or the Mapps?
No aplicable
It's Mapps I think. It's the whitey sort of grey one with Mori's own control.
AchimN
El estado se ha cambiado a: Implemented
@AchimN
I get radius errors on YX machining with X being the toolaxis.
I think the post changes the workplane from toolaxis being in Z to toolaxis being in X so to speak. So rotate it 90 degrees but the machine, of course, doesn't.
So the G2's and G3's are wrong I think.
This is with useArcTurn =  true. If I don't set that to true it will do Y-axis moves during radii when turning.
Solved that.
In ArcTurn the machine doesn't like helical moves.
AchimN
@Laurens-3DTechDraw Thanks for your feedback, this is fixed into the latest version.
No aplicable
I get the message that the second spindle is not available.
Is there a way to make the second spindle available or are you planning to add this function to your post?
Our controller is currently an 840D
@Anonymous
By default there is a setting in the post that controls if the machine has got a secondary spindle and it is set to false.
Find this line in the post:
var gotSecondarySpindle = false;
Set it to:
var gotSecondarySpindle = true;
Since the post is still in BETA officially please test carefully.
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Enviar idea
