Generating *.cps post processing file form a *.pp file
Hi guys,
We have a 3-axis CNC router but the manufacturer in Mexico makes only a *.pp post processing file available for us. This totally splits our workflow and we would like to generate our cutting files directly with Fusion 360. Wanted to ask if there would be someone available that can give us a quote to adapt our *.pp file to the needed *.cps file.
Hereby the code.
+ Vectric machine output configuration file
+ History
+ Who When What
+ CRIVAS 03/01/2017 NK105
POST_NAME = "AsiaRobotica-NK-WB1.2 (*.nc)"
FILE_EXTENSION = "nc"
UNITS = "MM"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 1
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR PLUNGE_RATE = [FP|A|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"M6T[T]"
"G90 G17"
"G54"
"M3"
"[S]"
+ Commands output at toolchange
begin TOOLCHANGE
"M05"
"M6T[T]"
"M3"
"[S]"
+ Commands output for rapid moves
begin RAPID_MOVE
"G00 [X] [Y] [Z]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"G01 [X] [Y] [Z] [F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"G01 [X] [Y] [Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"G02 [X] [Y] [I] [J] [F]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
"G02 [X] [Y] [I] [J]"
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"G03 [X] [Y] [I] [J] [F]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
"G03 [X] [Y] [I] [J]"
+ Commands output at the end of the file
begin FOOTER
Thanks in advance!
1 Comment
ozgetokul
Observer
Hi, didi u find any solutions?
