End of Program Stop Location
For reference we run HAAS VF4 machines with a TRT210 Trunnion head.
Current Post does not allow for you to select machine location at the completion of a program.  It would be beneficial to have a simple selection in the Post to choose where you would choose to send the machine at the end of the program.  It currently always sends the trunnion to B-0 and C-0 at program completion.  For access reasons to the platter due to machine configuration we don't want that, and would be great if we could have control of where the machine ends.  Only current functionality would be to do a NC "passthrough" however that isn't even at the end of the Post, so we have to add an optional stop immediately after that, then change that part before the program is actually over.
This could be used for many reasons, if your doing lots of vice work, or special fixturing and would like the table location and/or trunnion to be specific to make changing parts easier without requiring manual moves by the operator without having to manually edit your posts.
