This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Create a stock Okuma Turning Post
Please create a Stock Okuma Turning posts.
Edit from HSM Post Team:
  • Please attached any relevant documents you have for Okuma turning machines to the comments
  • Once the Beta version of the post is completed we will post a link to it in the description her
UPDATE:
Initial beta version is available here:
http://cam.autodesk.com/posts/?p=okuma_turning
15 Comments
al.whatmough
Status changed to: Accepted
This one is already in Progress
JackalMFG
You dont know how awesome this is @al.whatmough!
Thank you guys for working on this.
al.whatmough
@JackalMFG  Now I need you to be awesome and test it for us.
JackalMFG
Absolutely @al.whatmough, I have another Okuma machinist I will get to test also! Thank you guys for working on this!
Robert_Allport
I am trying the post on a Okuma Cadet CNC Lathe (OSP5020L Controller) and a Okuma Crown (OSP700L Controller) .
I am wondering ..."Anyway to trim the Lead Zeros on the X, Z, F, etc.?"
See below code in "red".
(FACE1)
N20 T010101
M8
G95
G50 S1200
G96 S6 M3 M41
G0 X3.3 Z0.
G0 Z0.0716
G1 X3.2131 F0.03937
X3.1 Z0.015
X-0.0625 F0.005
X0.0506 Z0.0716 F0.03937
G0 X3.3
Z0.0666
G1 X3.2131 F0.03937
X3.1 Z0.01
X-0.0625 F0.005
X0.0506 Z0.0666 F0.03937
G0 X3.3
Z0.
AchimN
@Robert_Allport, that is possible of course. We can add a property for this later. Right now we are more looking for feedback if this post runs machines without any issues, all "cosmetic" changes can be done afterwards 😉
Robert_Allport
AchimN,
     Here is a little feed back on the Okuma Post:
The Post Needs to output a "%" sign for Start and End of NC Code. That didnt seem to be happening
in the Test (Okuma Generic) post.
Also;
       The post was outputting to "Slow" of an Spindle RPM for the controller. On our machine 50
rpm is the slowest acceptable rpm or the machine will not move. When I edited the NC file and changed the S6 to S50
the machine accepted it and proceeded with the next code. The part was programmed in CSS. See Below:
N20 T010101 (0. GENERAL TURNING)
M8
G95
G50 S1200
G96 S6 M3 M41                      >>>>>>>   "S6" RPM to Slow For Controller. Should be Min of 50 rpm
G0 X3.4 Z.1969
G0 Z.0104
G1 X3.1131 F.03937
AchimN
@Robert_Allport, thanks for your feedback!
The updated post will show up into the library soon.
Changes:
- added "%" at the beginning and end of the program
Regarding the RPM issue:
The post is just using the values you defined into the operation.
Of course i could generate a warning / error if the rpm is above/below any value, but this can be different from machine to machine.
So the easiest way is to take care of this by programming the operations.
Robert_Allport
AchimN,
            I believe that I did set the rpm correctly (See Picture Below).  However I do agree with you that it may be different from machine to machine. So perhaps the best way (?) to handle that would be to add a "line" (MinimumSpindleSpeed) to the "User Defined Properties" list under the "MaximumSpindleSpeed"  so that value could be entered and stored and used in the JS code .
AchimN
@Robert_Allport you are absolutely right, there was an issue regarding this (unit issue).
Updated post will be online soon.
Thank you so much for your feedback!
AchimN
This post processor is public now.
tommyKS2VG
yea, i am looking for the post processor for OKUMA OSP700L too
i need help.
I need a post for the OKUMA   OSP-P300LA-e.  Does anyone know where I can get one?
Are there vendors who build custom posts?
Robert_Allport
I have one for a OSP502L and OSP700L. I dont know if they will work, would you like to try it.
scottmoyse
Hi Rich,
We can help you get one sorted if you don't find one from the community.
