Z-Shift
Z-Shift
Z-Shift
Would it be possible to change the post so that it puts a Z-shift in the program?
That way the operator could enter the thickness of the wasteboard or easily make slight adjusments to the depth.
This is what mastercam gives us for our thermwood router:
(Material Thickness)
SET THICK1=0.675
(Fixture Height)
SET FIXTURE1=0.500
[ZSHIFT=THICK+FIXTURE]
Kieran
Laurens-3DTechDraw
Does the Thermwood understand the ZSHIFT command like that? Nothing more to change to the code than those lines?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Yup, I coppied that directly from an NC file.
Is this something that would be hard to do?
Laurens-3DTechDraw
No it's quite easy actually.
Laurens Wijnschenk
3DTechDraw
René for Legend.
That's good to hear,
Could you explain how to do it?
I don't have a lot of experience customizing post processors
Laurens-3DTechDraw
To keep it all easy I made a post for you.
From the generic Thermwood.
What is new in there are two post processor properties. aThickness and aFixtureHeight.
You can set them during post processing if you already have an idea what the operator will fill in. If you don't leave them at the default 0.
And it will now always give you this code:
G90 G94 G40
G990
M48
G96
G17
G71
G805 (Acceleration Macro)
G9 F1 (Tangency Factor)
SET THICK1=0
(Fixture Height)
SET FIXTURE1=0
M5
G46
G990
G0 Z0.
Laurens Wijnschenk
3DTechDraw
René for Legend.
