hey guys,
I'm struggling to make my post do what i want to safely clear my sub spindle. I need it to move to the clearance height in Z FIRST before moving down in the X.
Here's what i have:
(DRILL1 2)
M1
T0202
G50
G98
G97 S468 M3
G0 X0. Z15. (I want this to be 2 lines - G0 Z15 and then X0)
G17
G0 Z5.
Z15.
Z5.
G83 X0. Z-2. R0. F58.5128
G80
Z15.
G28 U0.
G28 W0.
My modded post attached if someone wants to just change it. thought if someone could point out how to change it to suit would be great so i can learn.
Cheers,
Trav
Solved by ivan.stanojevic. Go to Solution.
I've separated that block of code.
Cheers
Ivan Stanojevic
Hi, I try to find what block you separated and no result.
Can you put more light to where is this change?
thanks
Marcin
