Hello, I am trying to work through my own post, however my machine is a bit special. lol.
I need to add "(" at the beginning of each line, and ")" at the end.
Like this:
(X1.)
(Y1.)
And also, I need to remove spaces between written blocks.
Currently they output like this:
M6 T2
and I need it like this
M6T2
And REALLY I need it like this:
(M6T2)
(X2Y2Z1)
I'm getting close to where I need to be, but I just cannot figure out how to remove spaces between written blocks, and also how to add blocks.
This is on the generic Fanuc milling post.
Subsequently, on the fanuc turning post, how to I make the tool number "T1" and not "T10101"? I've gotten it down to T0001, but can't figure out where the extra 000 is coming from.
Coding was never my thing.
Thanks!
Solved by boopathi.sivakumar. Go to Solution.
Hi @redcapjuice
All problem are simple edits
1. To add "(" and ")" after each line
go to function writeBlock
writeWords2("N" + sequenceNumber, arguments);
sequenceNumber += properties.sequenceNumberIncrement;
} else {
if (optionalSection) {
writeWords2("/", arguments);
} else {
writeWords("(",arguments,")"); //<< replace the old line with this one
Also you have to set the set sequence number to no
2.To remove spaces we already have user defined property named "Separate words with space" you can set to false by default in the post
separateWordsWithSpace: false, // specifies that the words should be separated with a white space
//<< set it to false here
3. change the toolformat to avoid the leading zeros.. like below
var toolFormat = createFormat({decimals:0, zeropad:true});
remove the width:4 form the line
It should work perfectly for you now
Thank you! I figured out the spaces right after posting this. The ( ) though, I was so close. I didn't add the quotes to make it "(" ")".
But now everything is looking proper.
Thanks again! Hopefully I'll get this thing running soon.
