I'm new to HSMWorks and am running it in Solidworks. It appears to work great, except no semicolon appears on any block when posting to "Haas Generic". Any suggestions? Thank you
Solved by Laurens-3DTechDraw. Go to Solution.
Because this is not needed.
It's just something to tell the machine you are on the end of a line when you are programming on the machine.
When you program externally the system already knows what the end of a line is. Because of the (Ascii 10 (LF)) which means line feed.
Fanuc and Haas use this as their EOB(End of block.)
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Thanks for your help. Our Haas machine accepted .NC files saved from the post processor. On the Haas display, semicolons were automatically added to each block. Great fun. Thanks
Laurens Wijnschenk
3DTechDraw
René for Legend.
