Updated Mitsubishi Laser Postprocessor (LC10BV)
stoltenkamp.scott
stoltenkamp.scott
Based on the 07/01/2019 postprocessor available here.
Fixes:
Forced decimal point on integer XY coordinates (X1 is by the controller as X.001, this corrects that output to X1.)
Tweaks
O#(program-name) is now posted from data entered in program number/name in NC program
Pierce routine "P9010" (Standard-pierce) set as default instead of P9009 using cutting table entry 110
Cutter comp mode "B" set as default
New Functionality:
Etch "P9008" output from cutting toolpath when cutting mode "Etch" is selected using cutting table entry 108
ETCHING!ETCHING!
Vaporize "P9005" output from cutting toolpath when cutting mode "Vaporize" is selected using cutting table entry 105
Todo:
Add pallet change setting in properties (Auto change currently commented out)
Notes:
Post tested in Fusion 360 and run on an LC10BV, seems to be working. However I'm no expert in .js or with this laser, so use AT YOUR OWN RISK!
Please feel free to send feature requests.
Thank you for the original postprocessor, and the related laser posts which were used as reference to cobble this one together.
We currently have one of these lasers in our shop. I was wondering if you could send me instructions on how to implement your new post processor.
