Hi am using the DMG Mori NHX post as a base post for our Mori Seiki NH5000. My Problem is the unwanted retracts (G28 homing) in between Work offset changes and cycles. I know that this is the safe way and I take the responsibility for the out come. But I would like to be able to just use a retract position. in stead if a full z axis homing. Is it possible to make it a Toggle in the properties?
Dave
(DRILL2)
T2 M06
M08
S6000 M03
G54
G00 B0.
G00 X5.375 Y0.375
G43 Z1. H02
G00 Z0.1
G98 G81 X5.375 Y0.375 Z-0.05 R0.1 F3.
X4.875
X1.625
X-1.625
X-4.875
X-5.375
G80
Z1.
G30 G91 Z0.
G90
G49
(DRILL2 2)
G00 X5.375 Y0.375
G43 Z1. H02
G00 Z0.1
G81 X5.375 Y0.375 Z-0.125 R0.1 F3.
X4.875
X1.625
X-1.625
X-4.875
X-5.375
G80
Z1.
G30 G91 Z0.
G90
G49
(DRILL2)
G55
G00 B0.
G00 X5.375 Y0.375
G43 Z1. H02
G00 Z0.1
X4.875
X1.625
X-1.625
X-4.875
X-5.375
G80
Z1.
G30 G91 Z0.
G90
G49
(DRILL2 2)
G00 X5.375 Y0.375
G43 Z1. H02
G00 Z0.1
X4.875
X1.625
X-1.625
X-4.875
X-5.375
G80
Z1.
Solved by KrupalVala. Go to Solution.
Hi @dave_ ,
Thanks I downloaded the new version it work well only had to change a couple things thanks.
