The Tormach Mill Post 41445 Generates code fine but the new post (41493) with the new inverse time function generates this error
The Code is identical from 41445 to 41493.
Chris
Information: Configuration: Generic Tormach PathPilot
Information: Vendor: Tormach
Information: Posting intermediate data to 'M:\Spinners\Dollar Spinner-3\Spinner Top - Superfly test.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, July 13, 2017 2:14:49 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41304
Configuration path: C:\Working Posts\Tormach-Mill-41493.cps
Include paths: C:\Tormach\Fusion 360 Tools\Working Posts
Configuration modification date: Thursday, July 06, 2017 2:15:43 PM
Output path: M:\Spinners\Dollar Spinner-3\Spinner Top - Superfly test.nc
Checksum of intermediate NC data: a1081bfb8af1fdcb95e0bf4a54c25943
Checksum of configuration: 2ac42d3554d642f109ad1481b6b08fde
Vendor url: http://www.tormach.com
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.3174
Error(C:\Working Posts\Tormach-Mill-41493.cps:1239): TypeError: gFeedModeModal is not a function
Stack dump:
onCircular(false,4.920000091312438,-2.670000031238466,0.23000000030036985,4.920000091312438,-2.670000031238466,-0.01000000031914298,15)@C:\Working Posts\Tormach-Mill-41493.cps:1238
Failed while processing onCircular() for record 280.
Error: Failed to invoke function 'onCircular'.
Error: Failed to invoke 'onCircular' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, July 13, 2017 2:14:49 AM
Post processing failed.
Faild NC Code
(Spinner Top - Superfly test)
(T2 D=0.25 CR=0. - ZMIN=-0.262 - flat end mill)
(T6 D=0.25 CR=0. - ZMIN=-0.26 - flat end mill)
(T9 D=0.375 CR=0. - ZMIN=-0.265 - flat end mill)
(T35 D=0.25 CR=0. TAPER=120deg - ZMIN=-0.04 - spot drill)
(T60 D=2.4 CR=0. - ZMIN=-0.01 - face mill)
N10 G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
N20 G20 (Inch)
N30 G30
(Face1 2)
N50 G30
N60 T60 G43 H60 M6
N70 S2500 M3 M8
N80 G56
N90 G0 X5.16 Y-2.67
N100 G0 Z0.6
N110 G0 Z0.23
N120 G30
N130 M30
!Error: Failed to post data. See log for details.
(Spinner Top - Superfly)
N20 G20 (Inch)
N30 G30
(Face1 2)
N50 G30
N60 T60 G43 H60 M6
N70 S2500 M3 M8
N80 G56
N90 G0 X5.16 Y-2.67
N100 G0 Z0.6
N110 G0 Z0.23
N120 G18 G3 X4.92 Z-0.01 I-0.24 K0. F15.
N130 G1 X4.1
N140 G1 X-0.5 F18.
N150 G17 G2 Y-1.1628 I0. J0.7536
N160 G1 X4.1
N170 G1 X4.8 F15.
N180 G18 G2 X5.04 Z0.23 I0. K0.24
N190 G0 Z0.6
N200 G17
N210 M5 M9
N220 G30
Solved by bob.schultz. Go to Solution.
I think that there is a typo in the newest Tormach post.
Instead of
gFeedModeModal(94)
it should be:
gFeedModeModal.format(94)
@bob.schultz could you take a look at this?
Ivan Stanojevic
Thanks for reporting this. The new inverse time logic was added to a number of posts and the Tormach post does have this problem in a few places. Here is a fixed version of the post that will be placed in the online Post Library shortly.
There is also a bug in the coolant function. If you select Disable the post still outputs the M8 if you have smartcool disabled.
Chris
Thanks, @bob.schultz. Could you also fix the coolant issue problem?
It has already been discussed here:
Ivan Stanojevic
Done.
