Tool Return Command Advice
mark.hannafordMCXEY
Message 1 of 9
mark.hannafordMCXEY
Hi, I have a Roland MDX540 and the post I am using is great except that my machine has an ATC installed. I would like to add to the post processor the M06T0 command so that the tool unloads after each program has ended. I have attempted to learn Javascript using Visual Studio Code but it doesn't make any sense to me. What would the command look like and where should it be placed before the script below or in between? Your advice would be appreciated, thank you.
function onClose() {
writeBlock("H"); // retract
zOutput.reset();
onImpliedCommand(COMMAND_END);
onImpliedCommand(COMMAND_STOP_SPINDLE);
writeBlock("H"); // spindle stop
function setProperty(property, value) {
properties[property].current = value;
Replies (8)
Message 2 of 9
Arun.rs
Hi @mark.hannafordMCXEY
Thanks for raising your concern via Forum.
I assume you are using Roland ISO post from F360 library.
Open post file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Add below code after line number 512 to print 'M6 T0'
writeBlock(mFormat.format(6)+" T0");
Hope this helps!
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
Message 3 of 9
mark.hannafordMCXEY
Hello Arun.rs,
Thank you so much for your advice. I have been trying on and off for a month to get this to work. I would never have got to your script. I did get close though writeBlock (mFormat.format(“M06T0”)). Anyway this is irrelevant.
I do have a question when I open Roland’s Post “roland.cps” (not sure if it is ISO or not) in Visual Studio Code, I only have a total of 284 lines. Am opening this up correctly?
Mark Hannaford
Message 4 of 9
Arun.rs
HI @mark.hannafordMCXEY
You can download Roland ISO post from below link :
https://cam.autodesk.com/hsmposts?p=roland_iso
Let me know if you need any help.
Regards
Arun.RS
Message 5 of 9
mark.hannafordMCXEY
Hello Arun.rs,
Thank you very much. It works to a point. The M06T0 appears on the tool change but not at the end of the code. I haven’t run it on my machine yet and I will tomorrow to see what happens. I okay I will contact you tomorrow and thank you for your help, it is very much appreciated.
Mark Hannaford
Message 6 of 9
Arun.rs
OK . Kindly test the output on machine and let me know the feedback. Happy to help!
If you need the code to appear in end of toolpath then,
1. Search ' function onClose() { '
2. Paste the same code just after ' onCommand(COMMAND_COOLANT_OFF); '
Hope this helps !
Regards
Arun.RS
Message 7 of 9
mark.hannafordMCXEY
Hello Arun.rs,
Thank you very much this Post now runs very well. I have noted that this Post generates an option stop between tool changes. Can you tell me how to remove that function. And at the very end of the program the tool gets put away, but then the empty spindle starts up and then stops for about 10 seconds. Have you got any advice on that.
Mark Hannaford
Message 8 of 9
Arun.rs
Thanks for the feedback !
To omit the optional stop, you can handle thru the property page. Refer the image.
For the empty spindle starts for 10 secs, I am not sure why this happens. You can hand edit the code like below and check on machine.
G0 Z15.
M05 >>>>>>>>>>> ADD SPINDLE STOP
G91
G28 Z0.
G90
G91
G28 X0. Y0.
G90
M30
Regards
Arun.RS
Message 9 of 9
mark.hannafordMCXEY
Hello Arun.rs,
Thank you and I didn’t see the properties box before. I feel really stupid to ask you such a stupid question. The adjustments I have made to the Roland ISO Post with regards to the tool unloading makes the machine program look like below. Now I can see referring to your example, the M5 is in a different place. Can I move the writeBlock (mFormat.format(6)+”T0”); to another place to get my output to match yours? The end of my Roland ISO Post looks like the below picture.
G0 Z15.
G17
M6 T0
G91
G28 Z0.
G90
M5
G91
G28 X0. Y0.
G90
M30
writeRetract(Z);
onCommand(COMMAND_STOP_SPINDLE);
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
writeRetract(X, Y);
writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
writeln("%");
Mark Hannaford
