Is it possible to put the tool render in the excel setup sheet like in the html one ? If yes how ? because I have been searching for hours to understand how without any result...
thanks for the help
See the toolRenderer variable in the HTML setup-sheet.
That is how the image is made in the HTML version.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Yep, like Laurens said, use the data from the HTML setup sheet:
define a two new variables:
var toolRenderer;
var exportedTools = {};
in onOpen add:
toolRenderer = createToolRenderer(); toolRenderer.setBackgroundColor(new Color(1, 1, 1)); toolRenderer.setFluteColor(new Color(40.0/255, 40.0/255, 40.0/255)); toolRenderer.setShoulderColor(new Color(80.0/255, 80.0/255, 80.0/255)); toolRenderer.setShaftColor(new Color(80.0/255, 80.0/255, 80.0/255)); toolRenderer.setHolderColor(new Color(40.0/255, 40.0/255, 40.0/255));
in onSectionEnd add:
var id = tool.number; var path = "tool" + id + ".png"; var width = 2.5 * 100; var height = 2.5 * 133; try { if (!exportedTools[id]) { toolRenderer.exportAs(path, "image/png", tool, width, height); exportedTools[id] = true; // do not export twice } } catch(e) { // ignore }
Once you have this inserted, you should get the tool image in the same folder as the setup sheet. I use excel VBA to pull the images in and place them usually
Good morning, I am returning to the post after a long time as I have recently discovered the possibility of creating installation sheets in excel format. In the post I tried to insert the suggested instructions and during processing I don't receive error messages but the creation of the images of the tools is not even performed. I can't figure out where I went wrong. I'm attaching the post I edited if it helps.
Best regards.
