Tool Change Position and Full Retract
Just thought I'd share a post edit that I performed for a friend today. He's running a tall part on a Haas Mini Mill and needed to insert a tool change position that would retract the tool to the full height (G53 Z4.) and then move the part away from the carousel, and after the tool change would move the tool back to clearance height before moving to the work offset.
Although there are a few hardcoded numbers (easiest to do on a lunch break) this wouldn't be too difficult to pull from the machine configuration in HSMWorks or the stock definition in any of the HSM flavors I think.
I created a user property called toolChangePos and modified a couple sections like so:
Starting at line 737
// retract to safe plane
retracted = true;
if (properties.useG28) {
if (properties.toolChangePos){
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(4));
writeBlock(gFormat.format(28), gAbsIncModal.format(90), "X" + xyzFormat.format(-16), "Y" + xyzFormat.format(0));
} else {
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0));
} else {
gMotionModal.reset();
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), "Z" + xyzFormat.format(4));
writeBlock(gFormat.format(53), gMotionModal.format(0), "X" + xyzFormat.format(-16), "Y" + xyzFormat.format(0));
} else {
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), "Z" + xyzFormat.format(0));
writeBlock(gAbsIncModal.format(90));
zOutput.reset();
and line 803
writeToolBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
if (tool.comment) {
writeComment(tool.comment);
} else {
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(4), "Z" + xyzFormat.format(0));
Critiques and feedback welcome.
Post attached.
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
