Post Parameter list?
In Fusion 360, I'm starting to modify my post for Mach4 Lathe a little and I'm wondering if there is a listing of cycle parameters for the java?  For instance, in a deep drilling Cycle (I need G83 not the G81 that was there, but I fixed that) - The peck that is written to Q is some equation of the values that are input for peck depth, first peck, and minimum peck.  I just want to use the value you put in peck depth to write the block for Q.  It uses cycle.incrementaldepth right now and that's obviously wrong.  If I have Peck Depth and Minimum Peck set to the same value (say 0.01) then Q is posted at 0.02 or double the value.
I guess I'm looking for an excel or similar listing of the values/parameters to used to modify the posts to suit our needs.  Anything out there?  Thanks!
Laurens-3DTechDraw
These two threads will guide you along: http://forums.autodesk.com/t5/post-processors/help-my-post-processor-needs-to-be-edited-now-what/td-...
http://forums.autodesk.com/t5/post-processors/getting-started-modify-posts/td-p/6371381
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
