tool change needs referance pls help
tugaysamanci
tugaysamanci
Hello, I own an old Feeler VMC. The Z-axis travel is very limited, so for safety reasons, the machine needs to return to the reference position before every tool change.
I manually add the following lines before each tool change:
G80 G91 G30 Z0.
G91 G30 X0. Y0.
T1
M06
If i dont add the code the machine won’t change tools. Is there a way to modify the post processor to automatically include these lines before each tool change?
billcainautodesk
Hello @tugaysamanci
You can change the settings for retract. onToolChange was set to false. You can tell it to send the tool home in X and Y.
retract: {
cancelRotationOnRetracting: false, // specifies that rotations (G68) need to be canceled prior to retracting
methodXY : undefined, // special condition, overwrite retract behavior per axis
methodZ : undefined, // special condition, overwrite retract behavior per axis
useZeroValues : ["G28", "G30"], // enter property value id(s) for using "0" value instead of machineConfiguration axes home position values (ie G30 Z0)
homeXY : {onIndexing:false, onToolChange:{axes:[X, Y]}, onProgramEnd:{axes:[X, Y]}} // Specifies when the machine should be homed in X/Y. Sample: onIndexing:{axes:[X, Y], singleLine:false}
Bill Cain
Sr. Technical Consultant
