Message 1 of 8
When I edit the spindle speed between 2 similar or identical operations, the post fails and produces this error message:
Error: Mismatching arguments for invocation of 'string FormatNumber.format(Number) const' (Value is not a number.).
Error at line: 406 (dynapath-B6GX5.cps)
Error in operation: '2D Pocket3 (3)'
Failed while processing onSection() for record 1636.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Sunday, June 22, 2025 4:54:17 PM
Post processing failed.
I've been comparing this post with others that do work OK and I'm stumped. I've attached a sample model, the post, the code produced, and the error log.
In the model I changed the feed between 2Dpocket 1 and 2, and changed the spindle speed between pocket 2 and 3. It processes the feed change OK, but not the spindle speed, it fails before processing pocket 3. I can post process the model OK with other posts for other machines. What did I do wrong here?
Model - https://a360.co/44ebF4A
