TNC 410 tool call M6 missing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good afternoon guys we are having a problem with post processor the issue is i have to manually delete items and add items to the .H file before running on the machine i.e. the M6 command below the tool change command was missing also at the beginning and end of the program a few lines down there is a command to defend full rapids to z0 witch as you would expect could cause a crash so i delete said section we have been successfully using this solution for a quite some time but as you can expect a large file with loads of tool changes manually removing stops and adding the m6 command can take some time
is there a way of editing the post processor ?
for example please find attached before and desired after and the current post we are using (please not that tool def is removed also)
It would be fantastic for this small issue to be sorted out for us
