Syntax errors in Autodesk Mill/Turn posts
I was working on a Mill-Turn post so I downloaded some existing ones to compare and get some insight.
But then I came across  several non-functioning posts with syntax errors:
https://cam.autodesk.com/posts/post.php?name=nakamura%20mill-turn%20fanuc
Faulty code at line 3177
https://cam.autodesk.com/posts/post.php?name=doosan%20mill-turn%20fanuc
Faulty code at line 3347
https://cam.autodesk.com/posts/post.php?name=takisawa%20mill-turn%20fanuc
Faulty code at line 2941
Interestingly enough every instance of the faulty lines are in the same function and are the same
There are more Mill/turn posts available on https://cam.autodesk.com/hsmposts? that have the same problem!
Im not sure what could have happened but this should be fixed.
bob.schultz
Thanks for bringing this to our attention.  The mill/turn posts located in the online Post Library seem to have become corrupted, they do not match the posts located in our local library.  We will find out what the issue is and upload the correct posts.
Thank you
Bob Schultz
Sr. Post Processor Developer
Thanks, please keep me updated on the status
jeff.pek
We believe this is a glitch in the component that displays the post on the web site. If you download the post, you should see that it's fine.
Jeff
