smoothing problem mori
dave_
dave_
Hi I have a mori seike with a MSX-701 control (fanuc 31). My machine does not have a full 4th only a positional ( 1 degree) . the problem I have is with b axis and the Smoothing. The post does not turn off the smoothing (G5.1Q1)  when there is a B axis commanded because the B axis is thought of as a full axis and the look ahead would be reading it. But because I have a positional 4th it is not seen by the smoothing and skips over it. So in the program if there as a b axis commanded it does not rotate. Is it possible to get the post to see that the B is a full 4rth or not and the smoothing is turned of and on accordingly?
(2D CONTOUR6)
T6 M06
M08
S3600 M03
G54
M11
G00 B0.
M10
G332 R4.
G5.1 Q1
G00 X-1.25 Y-0.625
G43 Z1. H06
G332 R3. (need to bee added when B-axis is continuous = false)
G5.1 Q0  (need to bee added when B-axis is continuous = false)
G30 G91 Z0.
G90
(2D CONTOUR6)
G55
M11
G00 B0.
M10
G5.1 Q1  (need to bee added when B-axis is continuous = false)
G00 X-1.25 Y-0.625
G43 Z1. H06
M09
G30 G91 Z0.
G90
G49
G332 R3.
G5.1 Q0
G30 G91 X0. Y0.
G90
M30
Dave
dave_
 sorry I am using DMG Mori NHX with CELOS control for the base post
bob.schultz
Hello Dave,
You can modify the post to turn off smoothing when the B-axis changes in an operation.  Change the following line towards the top of onSection to disable smoothing when the work plane changes.
    // retract to safe plane
    writeRetract(Z);
    if (((insertToolCall || newWorkPlane) && !isFirstSection()) || forceSmoothing) { // <<< ADD the test for 'newWorkPlane' to this line
      disableLengthCompensation(false);
      setSmoothing(false);
We will update the library post so that this happens by default when the rotary axis is a positioning axis only.
Bob Schultz
Sr. Post Processor Developer
dave_
Hi Bob I have made the changes to the post and it partially works. It will only do the smoothing on and off if the B angle changes. So if I have a G54 B0. then a G55 B0. it will not turn the smoothing on and off but if I have G54 B0. then a G55 B15. It will force the Smoothing on and off. How can I force the smoothing? for repetitive B axis?
Dave
KrupalVala
Hi @dave_ ,
Please add the newWorkOffset to the to Bob's given solution.
    if (((insertToolCall || newWorkOffset || newWorkPlane) && !isFirstSection()) || forceSmoothing) {
Save the modification and test the code.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
dave_
Thanks I have it sorted out now.
