Sinumerik 810D turning-milling/
uladzimiruser
Message 1 of 12
uladzimiruser
Good day to all. Interests here what question. I am testing the postprocessor for the Sinumerik 810D turning-milling machine. Some things I did, but the question remained with the output of the M6 command after calling the tool.
G18
DIAMON
T3 d1
M6
SETMS (1)
G97 S1 = 500 M1 = 3
G94
G54
D3
In our machine there is no such function, and as far as I understand it from a milling machine. How to disable it.
Machine DMG CTX 310 ecoline 2008.
Since there is no Y axis in the machine, then the translation of XY to XC is carried out by the TRANSMIT command?
Replies (11)
Message 2 of 12
bob.schultz
It is pretty simple to get rid of the M6 code, you just need to comment out the following line in the onSection function.
    writeBlock("T" + (properties.toolAsName ? "="  + "\"" + (tool.description.toUpperCase()) + "\"" : toolFormat.format(tool.number)), dFormat.format(lengthOffset));
    // writeBlock(mFormat.format(6)); // comment out this line
The TRANSMIT command is used to enable polar interpolation on the control, where it will use the C-axis to compensate for the Y-axis moves.  If your control does not support this feature, you can disable it and the post will then calculate the XC positions to compensate for the XY positions without using the TRANSMIT capability.  You can enable XZC mode in the post by modifying the following line at the top of the post.
var gotPolarInterpolation = false; // specifies if the machine has XY polar interpolation (TRANSMIT) capabilities
Bob Schultz
Sr. Post Processor Developer
Message 3 of 12
marius_micromet
Hi
I need post procesor for sinumerik 810 turn-mill for ctx 510 . One that works post .
Who can help me ???
Thank.you
Message 4 of 12
KrupalVala
HI @marius_micromet ,
We have a DMG CTX beta 800 TC post. This post has not been released yet. Its in beta version. But you can download it from Here. Before any Machining trial cut, please test the codes carefully.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Message 5 of 12
marius_micromet
i
Message 6 of 12
KrupalVala
Hi @marius_micromet ,
We have Siemens Mill-Turn post. You can try with it.
Krupal Vala
Message 7 of 12
marius_micromet
Hi
 The post-processor sent if it is the same as the one in the post libray of the sait fusion 360 does not work becase i tested that one
Message 8 of 12
jcassidy.me
Is there any indication that the post will be developed more in the future and moved out of beta testing? From what I have done so far, the post seems really close. It would be a shame to see all of the work done on it so far by the HSM team be in vain.
Message 9 of 12
bob.schultz
Hello @jcassidy.me, I assume that you are asking about the DMG CTX_800 Beta TC post since the Siemens Mill-Turn post is already released.  You say the post seems really close, can you report any issues that you have found with the post?  Our goal is to get all posts in Beta officially released, but this requires feedback from the community to either report issues with the post and/or verify that it works on their machine.
Thanks!
Bob Schultz
Message 10 of 12
jcassidy.me
 I can certainly start to provide some feedback as I begin testing in the next few weeks. Thanks for the quick response.
Message 11 of 12
jcassidy.me
Ok, I am continuing to generate some initial code from the ctx post, and comparing it to some code I know works in the machine I can already start to see some minor, and some very serious errors. Please let me know where I should start directing all of my feedback to (separate forum, email, etc...).
Message 12 of 12
cipriansmartservices
Observer
Observer
I also need help with the post for a Sinumerik 810D turning-milling ctx310 dmg mori
