Siemens Turning 802d omit G97 and Change G18 to G17 for Drilling
paul.slaterMZZFE
Message 1 of 26
paul.slaterMZZFE
Could someone help please? i am using the Generic Seiemens post for turning and i need to Omit the G97 (line N19)and change the G18 (line N10) to G17 for drilling (which will need to be switched back to G18 for normal turning. below is a sample of a simple drill code:
; %_N_1001_MPF
N10 G90 G94 G18
N11 G71
N12 LIMS=4000
N13 T0
N14 G53 G0 X700.
; Drill2
N15 T6 D1
N16 G54
N17 M8
N18 G94
N19 G97 S2890 M3
N20 G0 X0. Z15
N21 F231.498
N22 CYCLE82(5, 0, 5, -25, )
N23 X0.
N24 G0 Z15
N25 M9
N26 T0
N27 G53 X700.
N28 M30
can someone help please? Regards Paul.
Replies (25)
Message 21 of 26
infoNQ5RB
@boopathi.sivakumar
Good afternoon,
I'm having the same issues.
I Need G17 for drilling and tapping Cycles.
To understand it right. What do you use as trigger? Is it possible to trigger on specific cycles? Like  Cycle83 and Cycle84
What code do I use then.
Kind regards and thanks for your help in advance
(I tried your post but it gives problems with a roughing Cycle95)
Error: Cycle 'turning-canned-rough' is not supported.
Error in operation: 'Profile Roughing3'
Failed while processing onParameter() for record 485.
Message 22 of 26
paul.slaterMZZFE
hi -i seem to remember that the drilling cycles required a G17 (this is to signify the XY plane)
if you have used my post this is in there. you MUST change back to G18 plane for normal turning in the YZ plane
i hope this helps. regards Paul
Message 23 of 26
infoNQ5RB
@boopathi.sivakumar
Hi Paul,
Thanks for your response!
Do you use your post still at the moment?
With an 802D control?
And do you have CYCLE95 in your codes as wel?
Message 24 of 26
paul.slaterMZZFE
hi -yes I occasionally do use the post.
sorry, i don't use Cycle95
Kind regards Paul
Message 25 of 26
infoNQ5RB
@boopathi.sivakumar
Oke thnx foor your help!
Message 26 of 26
paul.slaterMZZFE
A Pleasure! Paul
