SIEMENS 840D POST PROCESSOR MODIFICATION NEED IT
sinan-ba
sinan-ba
PLEASE  NEED SOME EDITING TO SIEMENS 840D  POST PROCESSOR , I ATT. A TEXT FILE SHOWING THE EDITING REQUIRED.
THANKS IN ADVANCE
boopathi.sivakumar
@sinan-ba
Edit the post like this below
add the code in red "//"
if (insertToolCall || newWorkOffset || newWorkPlane) {
    // retract to safe plane
    //writeRetract(Z);
    if (newWorkPlane && useMultiAxisFeatures) {
      setWorkPlane(new Vector(0, 0, 0), false); // reset working plane
And
    if (lengthOffset > 99) {
      error(localize("Length offset out of range."));
      return;
    //writeBlock("T" + (properties.toolAsName ? "="  + "\"" + (tool.description.toUpperCase()) + "\"" : toolFormat.format(tool.number)), dFormat.format(lengthOffset));
    //writeBlock(mFormat.format(6));
    if (tool.comment) {
      writeComment(tool.comment);
And finally in onClose
function onClose() {
  writeln("");
  //writeRetract(Z);
  setWorkPlane(new Vector(0, 0, 0), true); // reset working plane
  if (properties.homeXYAtEnd) {
    writeRetract(X, Y);
Save the file now and test it
Boopathi Sivakumar
Senior Technology Consultant
sinan-ba
Dear Mr Sivakumar,
Thank you very much for help, I could made successfully some modification, maybe you did not noticed  that others I need.
Please I need also to add
(percent sign)    at the beginning  & also at the end of the nc file.
   (semicolon sign)  at the beginning of line    ;WORKPIECE (,,,,,ex.....)
That is will be all, Thank you in advance
boopathi.sivakumar
@sinan-ba
Go and search for this line if (programComment)
and make something like below
  writeln("% " + translateText(String(programName).toUpperCase(), " ", "_") + "_MPF");
  if (programComment) {
    writeComment(programComment);
And search for this below portion do the changes ln red
  if (true) { // stock - workpiece
    var workpiece = getWorkpiece();
    var delta = Vector.diff(workpiece.upper, workpiece.lower);
    if (delta.isNonZero()) {
     writeln(
        "; WORKPIECE" + "(" + ",,," + "\"" + "BOX" + "\""  + "," + "112" + "," + xyzFormat.format(workpiece.upper.z) + "," + xyzFormat.format(workpiece.lower.z) + "," + "80" +
        "," + xyzFormat.format(workpiece.upper.x) + "," + xyzFormat.format(workpiece.upper.y) + "," + xyzFormat.format(workpiece.lower.x) + "," + xyzFormat.format(workpiece.lower.y) + ")"
At the end of the code in function onClose()
add the code in red
  onImpliedCommand(COMMAND_END);
  onImpliedCommand(COMMAND_STOP_SPINDLE);
  writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
  if (subprograms.length > 0) {
    writeln("");
    write(subprograms);
  writeln("%");
Boopathi Sivakumar
sinan-ba
Mr. Sivakumar,
Thank you very much , all are ok.... Please  see the att photo, I posted the same cam file , on the left is siemens 840D processor) &  the right one was posted with siemens 802D postprocessor.
As you can see RAMP on 840 D generated with G1 , but On 802 D The file generated with G3.
How can I let 840 D post processor output G3 & G2  instead of G1 , on RAMPING operation ?
Thank you , My best regards
