Roeders 5 Axis post-processor problem: Error: The probe cycle 'probing-y-plane-angle' is machine specific and must always be handled in the post configuration.
bernard5BABD
Message 1 of 10
bernard5BABD
I am a bit stuck here. Probing WAS working just fine. Since then, I did my best to "merge" drilling operations for the 3 axis post-pro (Found in the Post Library). Problem is, the structure is very different between the 2, and I am sure I messed up somewhere.
The thing is, this error appears nowhere in the code, so I am unable to find what triggers it. Your help will be greatly appreciated.
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
Replies (9)
Message 2 of 10
Tomek.G
Hi @bernard5BABD,
Probing and drilling operations use the same function onCyclePoint()
you probably overridden probing cycles and case "probing-y-plane-angle" not exist in your post anymore.
Tomek.G
Sr. Technical Consultant
Message 3 of 10
bernard5BABD
yes, it does, but I will look at onCyclePoint(), my mistake should be there.
Message 4 of 10
Tomek.G
@bernard5BABD,
I can take a look if you are open to share your post (have to be zipped).
Or share it in DM if you don't want to post it here.
Tomek.G
Message 5 of 10
bernard5BABD
it's still a work in progress, but "drilling" is OK (and the probe operations that I implemented are working). I am in the process of comparing the output from the Roeders 3 axis drillings operations to mine.
I got lost, as the structure is really not the same, and I have been confused (still am, just maybe a little less) by onCycle and onCyclePoint..
Thanks for your offer to help, I join the zipped file.
Message 6 of 10
Tomek.G
Hi @bernard5BABD,
The protectedProbeMove function is missing parentheses, so some arguments were not passed to the writeBlock function
  if (_z && z >= getCurrentPosition().z) {
    writeBlock((probeCode.code + probeCode.value), "P" + 9810, _z, getFeed(cycle.feedrate));
  if (_x || _y) {
    writeBlock((probeCode.code + probeCode.value), "P" + 9810, _x, _y, getFeed(highFeedrate));
  if (_z && z < getCurrentPosition().z) {
You have some missed semicolons also Lines 67, 627, 936, 1276, 1431, 1759, 2098, 2455, 2488, 2780, 2913, 2919, 3375
I would recommend you to install ESLint and ESLint VSCode extension.
It is a tool for identifying and reporting on patterns found in ECMAScript/JavaScript code, with the goal of making code more consistent and avoiding bugs.
Tomek.G
Message 7 of 10
bernard5BABD
Thank you very much. Did not know this tool. Right now it does not work, but I will make it work, should be extremely useful. BTW, I am surprised by Javascript "tolerance" with missing semi-colons.
Best regards,
Message 8 of 10
bernard5BABD
ESlint is now working, looks like a really great tool. Could you share your config file?  It was showing errors for ALL variables (undef), but I would like it to do that for really undeclared variables, not all of them!
Message 9 of 10
Tomek.G
Hit F1 and type ESLint: Create ESLint configuration
You can then edit it.
look at no-undef rule:
https://eslint.org/docs/rules/no-undef#no-undef
Tomek.G
Message 10 of 10
bernard5BABD
Yes, I managed to make it work after answering you. Very nice, it allowed me to clean my code and removed quite a few unused functions.
