Problem with Cycle81
janus2
janus2
Hello!
I use a variant of the generic Siemens turning PP for my EMCO Concept Turn 55.
Everything works fine so far.
But when I use Drill in Fusion 360 CAM it results in a Cycle81.
Cycle81 is not running on my EMCO. Not even the Cycle81 Siemens Examples is working on my EMCO!?
Is there a way to disable Cycle81 and write standard G-Code instead?
Thanks for any help
Jan
ivan.stanojevic
Yes, there is a way.
You might want to exclude some lines of code related to the Cycle81.
Those are located in OnCycle function in your post:
 case "drilling":
    writeBlock(
      "CYCLE81(" + zFormat.format(RTP) +
      ", " + zFormat.format(RFP) +
      ", " + zFormat.format(SDIS) +
      ", " + zFormat.format(DP) +
      ", " /*+ zFormat.format(DPR)*/ + ")"
    break;
When you block/delete those it should output the clean G0/G1 code.
Ivan Stanojevic
janus2
Hello!
Thanks for the fast answer.
This did the job. Now it is clean code and should work.
Thanks again
Jan
ivan.stanojevic
@janus2
You welcome, you can do the same for other drilling cycles too.
Ivan Stanojevic
