Mazak Post_Optional Block
mike.schaffer
Message 1 of 12
mike.schaffer
I am trying to post an operation with a tool being optional.  It looks as if the post should be outputting the "/" needed for the block skip but it is not.  I dont know if i am missing something in the Post or if there is something different i need to do.  Attached is the portion of the post that i feel needs attention.
Writes the specified optional block.
function writeOptionalBlock() {
if (properties.showSequenceNumbers) {
var words = formatWords(arguments);
if (words) {
writeWords("/", "N" + sequenceNumber, words);
sequenceNumber += properties.sequenceNumberIncrement;
} else {
writeWords2("/", arguments);
function formatComment(text) {
return "(" + filterText(String(text).toUpperCase(), permittedCommentChars) + ")";
Replies (11)
Message 2 of 12
Laurens-3DTechDraw
Post processor looks good.
So we should be looking at all the steps.
Could you make a screencast maybe so we can see what you do and what the output looks like?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 12
denis_schoemaker
How do i do a screencast?
Message 4 of 12
mike.schaffer
How do i do a screen cast or screen shot?
Message 5 of 12
ivan.stanojevic
You can download it from the following link:
https://knowledge.autodesk.com/community/screencast
Ivan Stanojevic
Message 6 of 12
mike.schaffer
I have attached a screencast.  Let me know if there is something more that you would like to see of if i am missing something.
Message 7 of 12
ivan.stanojevic
As far as I know, if you select an operation as optional the post processor should mark the code from that op. optional and the post needs to be edited to support all of this.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Inventor-HSM/files/GU...
Ivan Stanojevic
Message 8 of 12
Laurens-3DTechDraw
You are doing everything right indeed.
Question now would be if you can upload that post processor?
Because I'm confused to why it doesn't work.
Laurens Wijnschenk
3DTechDraw
Message 9 of 12
mike.schaffer
attached is a copy of our Mazak Post.
Message 10 of 12
ivan.stanojevic
I've edited your post and implemented "optional section" exactly as Haas generic post has.
Ivan Stanojevic
Message 11 of 12
mike.schaffer
Thank You ivan.stanojevic.  I have tested it out and it seems to work.  Just to be clear though, the only thing you changed in the post was the section on Optional Block Skip? And is the Mazak and Haas basically fanuc posts?
Message 12 of 12
ivan.stanojevic
I've created a variable called optionalSection and implemented it into writeBlock function.
Then inside OnSection function I've assigned this variable to be "true" when the section is marked as optional.
However, this variable is set to be "false" in OnClose function because it doesn't have to take into account those blocks at the end of the gcode.
Don't know much about Mazak but Haas is Fanuc based indeed.
Ivan Stanojevic
