Hallo,
tested all PP from Forum for the Hermle C800U Heidenhain 430.
Newer Posts for HH and older 426.
Problem is an error " M128 nicht erlaubt bei 3D Rot" when going to the simultan operations.
3+2 Axis with Cyle 19 is okay.
Some idears ???
Michael
did you ever get your post working correct? i have the same model machine coming in next week off auction.
Hello @ahorwood and @KonstruktionBuero ,
I don't know what postprocessor you are using.
You can find here in the Post Library:
https://cam.autodesk.com/hsmposts?p=heidenhain_426
a generic Heidenhain 426 postprocessor.
I think you have just to activate and define your machine kinematics, as highlighted:
to make your first tests.
Please test it carefully and let me know.
i have modified the Post and make some tests. It works fine since now.
I would like to buy a C800u, 2001 with a HH430.
Is it possible to mill 5x simultaneously with this control?
Or should I opt for a machine with HH530?
it will mill 5 axis simultaneous. but a 530 would be easier. a few nice updates over the 430.
