G'Day,
i was trying to use doosan mill-turn fanuc.cps post processor for mori seiki - fanuc control c axis mill turn lathe (T6F2 Controller).
i am getting below error. would some one please provide suitable post processor. Thank you.
Error: The post configuration requires revision 45702 or later of the post processor which has revision 42270.
Failed while processing global script.
Solved by Arun.rs. Go to Solution.
HI @Anonymous
You are not running the latest version of CAM and your post processor requires a newer version of the post kernel.
You can use that version of the post processor which does not require the latest post kernel version.
https://cam.autodesk.com/hsmposts?p=doosan_mill-turn_fanuc
Regards
