Post processor for a Felder Format 4 machine
Message 1 of 20
Good afternoon HSM PP Forum!
I am looking for a post processor for Autodesk Fusion 360 for a Format 4 CNC workstation machine. The machine is from a company called Felder Group and the machine type is Profit H50. It's a 5-axis machine.
Felder Group:
https://www.felder-group.com/fg-en
This post (link below) describes there is currently not a released post processor for Felder Format 4.
https://knowledge.autodesk.com/support/hsm/troubleshooting/caas/sfdcarticles/sfdcarticles/Is-there-a...
I have contacted the supplier of the machine for help but they have yet to call me back. I will report back here if I am able to find a solution with their help.
Meanwhile I figured I could try and ask for help on this forum. Perhaps somebody here knows an alternative post processor that will do the trick, even though it might not be specifically designed for the type Format 4 machine.
Pascal
Replies (19)
Message 2 of 20
GeorgeRoberts
Thanks for posting! I'm currently working on a post processor for this machine. If you would like to test it and provide feedback, please email [email protected]
Many thanks
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 3 of 20
Hello George,
Thanks for the quick reply! Sadly I don't have easy access to the machine at the moment. I am located in The Netherlands myself and the machine is in Germany on an 8 hour drive for me.
I would love to try out some of the work in progress, and give feedback if I could, but the distance between me and the machine is too much to play around with it. I picked up a CAM side project from a friend in Germany who has access to that machine.
I know that the owner of the machine currently has little time to run tests with the machine. I wish I lived close to the machine right now!
I am not sure if my knowledge about post processors is sufficient to give usefull feedback. But I am happy to assist in any way if you think there is anything I could help with.
Do you know an ETA for the post processor you are currently working on?
Pascal
Message 4 of 20
George,
Are you working with the Autodesk team in Germany?
I know they are working on this with the Felder Team.
I ran a test for them a few weeks ago; it worked the same (lacked the same functions) as the H10 PP I downloaded from the forum a year ago.
I have an H08 and I am using the H10 pp with great success. (working around some features that are lacking).
I am available for private emails/phone calls/testing.
I'm getting ready to purchase the H500; so Autodesk/Felder/Myself have motivation for this to work asap.
Leland
Message 5 of 20
Mitnick_d
Hi guys,
Any development on this one? I'm planning to buy a 5 axis format 4 as well.
Kevin
Message 6 of 20
I use Inventor 2019 and have a Felder H08 (3-axis), the latest PP from George works perfectly with the spindle and drill head.
George would need to respond if/what anything is happening for the 5-axis machines.
Message 7 of 20
GeorgeRoberts
Thanks for posting. Please send me an email '[email protected]' and I can forward the post processor for the Felder machine. I'll also send instructions on using it for 5x operations
Many thanks
George Roberts
Message 8 of 20
Mitnick_d
Thanks a lot Geroge
I'll go in a few weeks at the Felder factory to use the machine a bit, and if I'll buy it, it get back to you
Thanks a lot!
Kevin
Message 9 of 20
GeorgeRoberts
Sounds good. Hope the testing goes well!
George Roberts
Message 10 of 20
We're running an H08 as well. I would like to try the pp for this one. Where did u find the pp for the H10?
Kind regards,
Message 11 of 20
I have an output that I can have made on a Felder Format 4  Profit H500 L machine can you please forward the information on the Post Processor for fusion 360 so I can output the file?
Thank you
Mark
Message 12 of 20
GeorgeRoberts
The Felder post processor is now public and can be found >>HERE<<. Please let me know if you find any issues
Cheers
George Roberts
Message 13 of 20
Mark,
Check the forum.
There is an official public version available.
Check it out.
Let me know if you have any questions.
Leland
Message 14 of 20
George,
Thanks for your hard work.
Is this one much different than the PP I've been running?
Leland
Message 15 of 20
GeorgeRoberts
I don't believe there is much different. The post team has done a few minor changes requested by other customers
George Roberts
Message 16 of 20
Cool.
Thanks again and Great Job!
Message 17 of 20
Hi George,
I have downloaded the post for the Felder Format 4, the parts loads but I am missing variable at the beginning of the program. I have attached a screenshot post from Cabinet vision ( on the left) and a post from Inventor (on the right).  Can you help?
Message 18 of 20
Dominic,
You stated the part loads.
Which machine do you have?
Once it loads, will it run the file?
Message 19 of 20
I am not the CNC operator, I am more the designer.  We can see the part when it loads but as he tries to edit it at the machine the toolpath disappears. The Machine is a Felder Profit 8 Format 4.
Message 20 of 20
Dominic,
First of all; TPAcad inserts several lines of code that is not needed.
I'm not sure what you are trying to edit in the machine.  Or, why would you try to edit something at the machine.
I do everything in Inventor, then Post-Process and run the parts; if an edit is needed, I just open my Inventor file, make the edits and create a new Post-Process TCN file.
Please explain in more detail.
I'll do my best to assist.
