Post processor for a CMS cnc machine
I am looking for a solution to post process toolpaths made in Fusion 360, for a CMS cnc machine. I can't find a post processor specifically designed for CMS machines. Perhaps somebody knows a post processor in Fusion 360 for a different machine, that will produce compatible g-code for the CMS machine.
Currently the owners of the CMS cnc machine programm with software called Hypermill. I attached a g-code file they programmed with Hypermill. I don't have the knowledge and experience to modify an existing post processor to be compatible with their CMS machine. Perhaps this is possible with minor modifications.
Hope somebody can help me out.
Pascal
It would be better to tell us what control brand and model you have since manufactures often use several controls on the same machine.
Hi Dave,
Thanks for the reply! I will keep this in mind for next time. For now my issue has been resolved because I found another CNC machine I can use instead of the CMS one. For the other machine I don't have the post processor problem.
Have a nice day.
Pascal
Lennart_Losjo
Great that you have solved your case.
But for others that are searching the internet for a solution of a similar problem it would be convinient if you post how you solved your problem, not just that you solved it.
Thanks.
Senior Product Specialist
Fusion 360, Inventor.
amberg47
i can edit it for you
